How can I fix an error w/ 3d?
When I go to view my model in 3D i am getting the error "Opposite edge list direction in pgon 133." How can I fix this?
Ingolf
Hello LizFortune!
Pgon means Polygon. You have got an Object that is not behaving well in your ArchiCAD File. My advice: Make a copy of your File by Choosing File - Save As. Then use the Copy and experiment a little. Remove Objects one at a time. Go to 3D every time. In the end you probably will come to a point where you will not see the Warning Message in 3D. Then you know whitch Object was the Culprit.
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
