I know this is not the place to ask for this but....
Can anyone please suggest a reliable CD BURNER software for PC/xphome? I have a CD with 519 mb data is not appearing at all. burnt with Roxio ECDC 5. Aarrghhh!
We're going to need a little more info to solve your problem. I've been using Roxio 5 since it came out, and I've never had a problem. With that being said, it can be very reliable. We just need to figure out what is causing your problem.
  • What version of Roxio 5.?.?.?
  • What CD-Burner do you have
  • What brand of CD-R(/W) media are you using
  • What method are you using to burn the cd?
    • Creating a Data CD in CD-Creator or drag & drop with Direct CD?
    • Disk at once, track at once?
    • other info, etc.
  • Have you tried burning with the built in burning capabilities of WinXP? (I know it's garbage, I turned mine off, but this can help isolate if it's the burner or not)
  • Is the disc readable after burning on your computer and not others, or it's not readable at all?
