stefan
Install 2 versions of ArchiCAD 16 with different hotfix?
I have AC16 with Hotfix 2 installed. This is the same Hotfix as we use on our BIM Server and the current available hotfix for the Belgian/Dutch release.
To be able to participate in Ecodesigner Star, you need to update to a newer hotfix (3) which is not available for our localized version and will disconnect me from our local BIM server.
Can you install ArchiCAD a second time and apply the hotfix on that version?
Archicad-user since 1998
my Archicad Book
2 Replies 2
You should be able to. In the old days we'd just copy the whole folder and that'd give us a second installation.
However you get the 2 versions of 16 on your machine, when you go to use the hotfix, it gives you a prompt to select which ArchiCAD you want updated. Which means you should be able to update one but not the other.
Jared Banks, AIA
Shoegnome Architects
Rafal SLEK
I've installed successfully this Hotfix-3 on my two working versions (POL and INT) + BIMserver changing folder only. So this should work also for Dutch/Belgian version too.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
