Installation failed (not enough space)
I was trying to install ArchiCad 10 Cze version, but near the end of unpacking it stopped and wrote that there is not enough space on disk, that it need of about 400 MB. The problem is that there are 4.5 GB free!!! If anyone has an useful suggestion what to do, I would be grateful.
1 Reply 1
Greg Kmethy
I believe you are installing the student version downloaded from the web. In this case, there is a known issue with the packing environment we use - it stops when you have more than 12GB free space. However, you should not hit this if you have 4.5 GB. Try to download the package again.
Gergely Kmethy
VP, Customer Success, Graphisoft
