Invalid protection key Windows tablet
I've just purchased a tablet with windows 8.1. Loaded Archicad12 on to the tablet but was unable to open other than Demo mode. Error protection key not found or not valid (128). Is it not possible to run Archicad on a tablet??
Thanks for your help
2 Replies 2
If you have it installed and it is running in demo mode then it looks like it should run.
The question is do you have your key plugged in (WIBU or Codemeter?).
If so then are the correct drivers installed.
Try installing the "License Activation" software to see if you key is being recognised.
http://www.graphisoft.com/downloads/licensing/
Thanks Barry I'll give it a shot
Bob
