2025-03-11 02:58 PM
Hello everyone,
I have downloaded the Archicad 28 English version and installed it, but the language of the program is completely in Italian, do you how I can change the language to English?
Solved! Go to Solution.
2025-03-12 01:57 AM
Are you sure you didn't install the Italian version?
It is a separate install for each language.
If you go to the HELP menu > About Archicad (or what ever that may be in Italian), what language does it show?
2025-03-11 03:05 PM
Can you maybe take a look in this thread? https://community.graphisoft.com/t5/Installation-update/Language-changing/td-p/573927
I assume AC28 UI language is in the same scenario.
2025-03-12 01:57 AM
2025-03-12 11:32 AM
Yes, I had been installed the Italian version unfortunately, so I uninstalled it and did it again with the English version. thank you for your answer by the way.
2025-03-12 11:33 AM
Thank you for your response, but I had to uninstall and do it again with the English version.
2025-03-13 02:26 AM
You can install both versions if you need them.
Just give them different installation folders when you install them.
Or install one and re-name the folder and then install the other.
You just need to make sure which version you are running.
I don't have different languages loaded, but I do have different build numbers.
