Installation & update
Launch New Instance of ArchiCAD - Doesn't Open Selected File
When I try to open a file using the File=>Open=>Launch New Instance Button method, the file doesn't open, but opens a new instance with a blank file, so I have to wait for that file to open completely, then open the file I want AGAIN.
I'm working in both AC12 and AC13, and it doesn't work in either version. I update faithfully, so I have the latest builds in both of them.
Any suggestions?
Megan
Mac OS X 10.5.8 on an old 1.83 GHz Intel Core Duo with a brand new HD
6 REPLIES 6
David Maudlin
Megan:
Make sure that you have the ArchiCAD file that you want to open selected in the Open File dialog box.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
I do have the file selected... I've tried checking the box first, then selecting the file (it's highlighted in blue), and doing selecting the file, then checking the box. Nothing works. I guess it's just a bug. In my program alone. For some reason.
Erika Epstein
You should be opening the application, archicad, first. The opening splashwindow gives you the choice to open an existing file or a new one.
Please add your version of archicad and computer specs to your profile.
If you still have trouble, reinstall archicad making sure your antivirus is disabled etc.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
To bring an old post back to life... Our office has been experiencing this problem. Several of the people in the office are having an untitled project opening when selecting a second file and using "Open new instance of Archicad". It doesn't happen on all of the machines, but I cannot figure out what the differences are. I have tried importing my work environment, thinking that was causing it, but it still opens a untitled for the second project.
Ok, what I managed to do to fix at least one of the computers...
First repair permissions; then go the users Library/Preferences/and delete:
com.graphisoft.AC 14.0.0 USA v1.plist
com.graphisoft.AC USA v1.plist
Also look in the the users Library/Preferences/Graphisoft/AC 14.0.0 USA v1/x 86 and delete:
ArchiCAD 14 DialPos.Prefs
ArchiCAD Basic.Prefs
Archicad will recreate these preference files and the only thing you seem to loose is the previously opened list of files.
Like I said, this fix worked for one of our machines, but I still have several others to go.
Hi Megan,
I had the same problem and the way it has work on my Archicad 13 is by opening a NEW file launching a new instance, then, once it has loaded the program, I load the file I want to work on.
I hope this is helpful.
Jorge Avila, Architect
