Chuso
Logitech MX Master 3S
I have recently purchased the above mouse with customisable buttons. All works fine but when having shift and command on two of the buttons it doesn't fully work in Archicad. Is fine when using the organiser but on te modelling window (it doesn't matter if it is a floor plan, section, 3d view...) it doesn't work. The buttons appear to function because when pressing them, the element highlight, however when keeping pressing and then left click, looks like stops that connection.
It works fine with any other Mac applications, so not sure what the problem is.
Any ideas?
Thanks
Chuso
3 Replies 3
Guru
So using just the mouse, you can shift click to select multiple things in other programs, but when in AC it deselects the previous?
I bought a S2 a long time ago, used it for a day, then returned it and got another G502 since the work mice don't allow you to do macros... Is this still the case?
Chuso
Hi Lingwisyer,
In other programs works fine, and in Archicad works fine too but only on the organiser. When using the mouse by pressing the assigned shift button for multiple selections it highlights the selection but when clicking left click it selects just the clicked element.
Chuso
I have just uninstalled the Logi Options+ software from Logitech and just use Steer Mouse. It works fine now, so it must be something to do with the software provided by Logitech.
