Lost Coordinate Box and Control Box
Silly question but need help. I seem to have lost both Coordinate Box and Control Box along bottom of screen. I have double checked the Windows/Pallet Display/Show or Hide both boxes, but it still does not show up anywhere when they indicate that they should be showing. I have had the boxes displayed in past, but now they are lost. Any help would be appreciated.
Thanks
Try to apply one of the stored Palette Schemes in the Work Environment Dialog and then check if you can bring the Coordinate Box and Control Box back.
If that does not help, try to reapply the Standard Profile 11 in the Work Environment Dialog and check then.
If that does not help, try to do a New & Reset to bring back the default Work Environment Settings.
Thanks Laszlo,
That did the trick.
