‎2004-09-20
09:11 PM
‎2025-01-30
11:59 AM
Molinda Prey
‎2004-09-20 11:35 PM
‎2004-09-21 03:01 AM
‎2004-09-21 06:42 AM
‎2004-09-21 04:14 PM
UWCAUP wrote:i've never used CCC, but the first thing that springs to mind is permissions . . does copying the WIBU stuff actually change the permissions on the files from a 'system' (or similar) owner, to the owner who's actually doing the copying?
When cloned to other lab machines with identical hardware (using Carbon Copy Cloner- an apple asr graphical front end) ArchiCAD no longer runs. It complains "protection key not found or valid".
I'd rather not have to reinstall on each individual machine. Anyone else have this problem and know of a workaround? Thanks.for your information: archiCAD 9 has the ability to create a network install package for CAD managers, who can set up defaults, profiles, templates, file paths, etc. on one single install and then use that to install around the office. not quite the same i guess, but worth bearing in mind?
‎2004-09-22 01:12 AM
