Resistopoulos
Migrating a project to another language version of Archicad.
Hi
I'd like to migrate a project (small-ish, single family house) from AC 26 International to 26 Swiss French.
What would be the best method?
Thanks, Alexandre
Archicad 26 / MacBook Pro 16" i9 / macOS Ventura (13.4)
1 Solution
The different language versions of Archicad will not translate the plans.
You will just have the INT file open in the Swiss version.
There is nothing really to migrate - just open the file in the other language software.
The biggest problem will be with the libraries.
The INT version library may or may not be compatible with the Swiss/French version library.
The only way to find out is to give it a try.
When you swap the libraries, if there are 'Missing' objects, you will have 2 choices.
Find those missing objects and replace them with what they should be.
Or delete the Swiss/French libraries and load the INT ones again - but of course they will be in English.
All text in the plans, you will have to translate yourself if you need to.
Go to post
