Florian99
Missing Archicad tab in Grasshopper-Rhino7 window
hi all,
I have installed and running: Archicad 25, Rhino7, Grasshopper, Archicad Grasshopper Connection BUT
I dont see that Archicad tab in Grasshopper:
Any idea what I could have missed?
Thanks!
BR, Florian
Archicad Grasshopper - AC tab missing in GH - 001.pngArchicad Grasshopper - AC tab missing in GH - 002.png
AC25, BIMCloud, Windows
1 Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for the report!
At the moment, there are 2 different packages for the Grasshopper connection: one is for Rhino 5 & 6, the other is for Rhino 6 & 7. I'm wondering if you installed the correct addon? If not, please uninstall the old one and download the correct installer from here (the one with sub text: Supports Rhino 6 and Rhino 7)
If it doesn't work, if you open the location: C:\Program Files\Rhino 7\Plug-ins\Grasshopper, do you see the file ArchiCADConnection.gha there?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Go to post
7 Replies 7
Aaron Bourgoin
check to see that you have only one connection installed. You can't have the connection on more than one version of AC.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Florian99
only one is installed - double checked
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Florian99
hi,
no
thanks!
BR, Florian
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thanks for the info! Have you tried reinstalling using the package mentioned in the link above?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Florian99
restart - reinstall solved the issue!
Thanks!
BR, Florian
Ambrus
I also don't see the Archicad tab in Grasshopper, and I got an error message when opening GH (see image attached).
I have Rhino 6, Archicad 26 4022 AUT FULL, and Grasshopper-Archicad 26 Live Connection (Rhino 6 and Rhino 7) from Oct. 28, 2022
I checked and the ArchicadConnection.gha is there in the Grasshopper folder.
Also already restarted all 3 programs and Windows, and the problem still persists.
Any help is appreciated, thank you.
