Model in 3D window creating problem
Hello
This is Samathuvam Working in Adroitec Information Systems Limited, Chennai. Adroitec is pormoting ArchiCAD in India, One of the coustmer who is using ArchiCAD10 facing lot of problem.
1. When a model is created in 2D if it is opened in 3D window while rotating the model all the elements are getting merged, For example Inner stairs and walls are also seen, like transparent.
2. In one of the drawing which is large in size, If the section is taken along the drawing cannot be seen, It says Virtual memory is low can't generate the section, but there is enough memory in hard drive.
Please give me the solution.
Regards
P.Samathuvam
A screen shot will help immensely in getting assistance with your problem. Also - what computer system are they using? PC/Mac Windows/OSX? What are the specs of the computer?
