KeesW
Mouse setup
I sometimes use Archicad at home. The computer has a wheel mouse but I can't get the PAN function to work on the mouse. I've looked on the Mouse hardware configuration in the XP Pro hardware setup but can't find PAN listed as an option to allcate to Archicad. When I installed AC10 on the office computers mouse shortcuts, including PAN, just worked and I didn't have to worry about it.
Any suggestions?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
2 Replies 2
Rod Jurich
KeesW wrote:
Any suggestions?
Check your scroll wheel to see if it can be assigned to
a "Middle Button/Click".
That will give you the Pan function.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
KeesW
Thanks Rod
Its surprising how such a small convenience makes such a difference to drafting and modelling.
