Narska
My subscription license does not work for Archicad 25
I have a yearly renewing subscription to Archicad.
I downloaded the new version: 25.
I can download a licence for 24 and it works fine.
But when running 25 I get a message "your license has expired"
When I click on "Start the license Manager Tool" I get a message: "Your license update was unsuccessful"
I have no option to update the license as the help says there should be.
What do I do?
Tomasz Mlynarski
New York based Architect
4 Replies 4
Hi Narska,
I had the same issue when I first downloaded and tried to run it. I phoned support and the guy I spoke to said the licenses hadn't been pushed out yet but should be shortly. Mine now works OK. I would phone them if it doesn't work by Monday.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Narska
Thank you!
Tomasz Mlynarski
furtonb
I have a similar issue with a perpetual hardware license with SSA.
AC25 is out, but the License Manager tells me my key is up to date - for AC24.
It's really annoying not having these in sync - why can't we just have the licenses updated prior the release?!
odv.hu | actively using: AC27-29 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
Some language versions of Archicad are released a little later than the INT, USA and other English language versions.
How long after or why this is so I can not say.
As you have the INT language version I would have thought you would be able to upgrade by now.
Probably best that you contact your local Archicad support people to find out what is going on - that is what you are paying the SSA for after all.
