2022-05-03 03:51 PM
2022-05-04 03:30 AM
Could you please translate what that error message says?
2022-05-04 05:19 PM
Everything used to work
But when the lights went out
Now it doesn’t work
And makes this mistake
2022-05-05 08:55 AM
Yes, I understand a power outage might have caused the problem, but what does the error message say.
I have no way to translate it as it is an image and not text that I can copy and paste into a translator.
Is it something about corrupt preference files?
2022-05-05 10:00 AM
Google:
Error opening cache file.
Error opening file: C\Users\...
2022-05-05 10:10 AM
I should have read the entire path of the error message and then I could see that it is to do with 'TWDataOption.xml'.
I would try just finding and deleting that file.
Hopefully it will just be re-created when Archicad is started again.
Otherwise maybe it will require a re-install of Archicad choosing the re-pair option.
2022-09-14 08:39 PM
no need to reinstall. you just have to delete this problematic file then restart the program
Said Y.
Archicad INT BIM Manager
