No online help AC23
I just installed the new AC23 AUS but maybe I hit a wrong button?
When I choose Help from the menu I'm being told that I need to download offline help and install.....
Here is what I get when I select ,<Help><ArchiCAD Help>
Please connect to the internet to access the up-to-date ARCHICAD Help online.
If you plan to work offline: copy the following link, and when you have internet access, use it to download the Help installer to your own computer, then install the Help.
https://redirect.graphisoft.com/?gstype=downloads&gssubtype=achelpinstaller&gslang=AUS&gsversion=23&...
BTW I am online....
Do I need to re-install or is there some way to link correctly to online help files
Thanks for any help!
Hugh
2 Replies 2
I think it depends on which Internet browser you have set as default.
I had Internet Explorer and it didn't work either.
I set Firefox as default and now it does.
But if you want the PDF help file then you have to do the download.
Or here is the Help Center page:
https://helpcenter.graphisoft.com/user-guide-chapter/84997/
