Nvidia Settings
hi,
i have just bough a nvidia quadro rtx 4000 and its suuuuuper than quadro p2000 i had before.
so, may you help me config the nvidia settings for archicad or even for twinmotion? or i leave it to the aplication manage?
probably the archicad and twinmotion have diferent sets.
best regards,
andré
1 Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi André,
Thank you for the question!
Unless you are using a laptop, usually comes with battery constraint (which is not the case here), GPU manufacturers did a pretty good job in order to optimize their cards out-of-the-box. If you don't have any issue with the new RTX 4000, there are not so many settings that can be changed in order to noticeably improve the performance when you run ARCHICAD.
I hope this will answer your question! Have fun with the new card! As a tech lover, I always get excited with a new piece of hardware
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Go to post
1 Reply 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi André,
Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
