Kenni Bach Andersen
PC specs
Hey you all...
just wondering, what PC´s your all running on ?
my PC is a Xeon E5-1620 v3 c.5GHz (have no idér if thats good or not)
32GB ram and a Quadro K2200 4GB GPU, seems a bit *********
all so running on a SSD, but not a super fast one, and 2x24inch screens...
whats the best CPU and GPU, for the program ???
1 Reply 1
Miha_M
System Requirements – Graphisoft
Yours might be a bit outdated, but for small sized projects it should work fine. Mine is even older and still works even on medium sized projects (although I am about to change it in a few days). If you plan on using the new redshift rendering engine you may have problems though, as the requirements for that one seem to be very high in terms graphic card requirements.
Redshift for Archicad – Graphisoft
A ssd based system & Archicad installation is good, a nvme would be even better (go and fetch a PCIe card for that, if you don't have a nvme slot on the mortherboard). 32Gb ram should be enough if you don't have many different programs running at the same time, but the more you have, the better everything will work. Your CPU is a 4 cores 8 threads one running up to 3.5 GHz, which is, as said, enough for smaller projects. It might even work with medium sized ones, depending on the level of complexity your project model will be developed to.
| Archicad 4.5 - 29
