Paste story to worksheet loses door/window outlines
Scott Bulmer
Not sure what is causing this:
If user copies from story one then pastes into a worksheet, outcome will work as expected. Copy from any other story & paste into worksheet will omit all door and window outlines (swings, frames, sash, etc). It should be noted that the identical procedure is followed for all stories. This is reproducable for me in multiple PLN files.
Has anyone else experienced this? Thanks, S
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Erika Epstein
Hi Scott,
I haven't tried it, but is it related to how doors and windows and walls are set to view relative to stories other than their own?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Scott Bulmer
Hey Erika, how's it goin'?!
I like your thinking, however if I copy a wall w/ door or window from story one and past onto other stories, THEN test copy/pasting from each story into a Worksheet, only the door/window from story one will paste as expected. So the walls including doors & windows have identical settings in all stories, however when copied from each story and pasted into a Worksheet, only those items from story one will paste as expected.
¡Ay, caramba!
