As seen in the attached image of a floor plan patch, a window located in the upper portion of a two story wall (above a door) is improperly included/shown in the patch. When the patch was created, only the doors showed, not the window above. This is completely repeatable.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Scott wrote: As seen in the attached image of a floor plan patch, a window located in the upper portion of a two story wall (above a door) is improperly included/shown in the patch.
don't use patches then!
~/archiben
b e n _ f r o s t b f [a t ] p l a n b a r c h i t e c t u r e [d o t] n z archicad | sketchup | morpholio | phpp
