ā2013-11-22 10:50 AM
ā2013-12-04 12:20 AM
ā2013-12-04 10:47 PM
methy wrote:
Not sure how helpful i can be for you with this but in a similar vein
we export our archicad files into artlantis for visualisation
we discovered that the bigger the file size the longer it would take in timeframe to render.
one of the oddities we found along the way in trying to reduce our own AC file sizes
was survey plans we received in imported dwg format 2d lines many many 2d lines very short some as short as dots and sometimes many hundreds of thousands of lines and some lines stacked on top of one another seemed to really slow things down oddly and that cleaning up these type of 2d elements made a reasonable difference to us. which makes no sense that getting rid of 2d elements make a 3d visualisation work better
I hope it helps or gives you some ideas of where to look.
ā2014-01-08 09:49 PM
ā2014-01-15 09:39 PM
ā2014-01-18 07:09 PM
ā2014-01-18 07:27 PM
