Plotmaker - Doors dissapearing
I've just updated some layouts in Plotmaker and most (not all) of the doors have dissapeared. I've redifined views, checked display options etc but does not correct problem.
Is this a bug or am I missing something.
7 Replies 7
aahatimo
maybe libraries did not load?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Are the drawings linked from the ArchiCAD file? There have been some problems reported with BGArchiCAD not loading all the libraries. Try a search on the subject, I know it's been discussed.
Gorazd
I had the same problem with one project. The file seem to be corrupted somehow, since three day old version worked fine. I also posted a question here on ArchiTALK but didnt fix the problem.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
Tried re-loading libraries but to no success, if a library was not loaded properly why would some doors appear but not others? I'm inclined to think this is a serious bug, how can I get around the problem
PS the client wants revised drawings asap!
Just tried injecting properties from doors that work - still no success. Also tried creating new doors and new doors with Window/Door maker, this also does not work. Could it be a problem with the walls rather than the doors?
Graphisoft are not saying much - is this a bug they are aware of????!!
Just discovered waht the problem was:
The doors which were appearing, were on a different layer to those which did not. Some how, unknown to anybody working on the project, an extra layer called "Doors in Interior Walls" appeared, which was invisible in the layer combination list for the setting out drawing. However, the doors were still visible. Once this layer was turned on for the combination everything appeared as it should.
Does anybody know if Theometrics Window/Door Builder could create this problem, however, it has only happened on one project so far??
Any comments Graphisoft?
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
The "Doors in Interior Walls", "Windows in Interior Walls" , etc. layers are created during importing the file into PlotMaker. These layers should only appear in PlotMaker, and definitely not in ArchiCAD. If these appeared in ArchiCAD just on their own, it is a bug.
As new layers are hidden in all layer combos, your output in PlotMaker will also have the doors and wall ends - which are on "Windows in Interior Walls" layer in your case - hidden.
The workaround of course is to make these layers visible in the layer combinations, once they appeared. Or simply delete them.
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
