Installation & update
Problems with drawings loading qith wrong versions.
Hi I dont know much about archicad because I dont use it but the company I work for does. (I work in the IT department) Anyways I have this problem were v10 drawings are opening in v8.1. And I dont have a clue why. I cant change default program in the file properties.
So I was wonder whether anyone on here knows whats going on.
thanks
Thomas Holm
Always open the program first (the right version) and then use the File> Open menu command from the program.
Yeh I know that works. But the problem is it never use to do it before.
Thomas Holm
You haven't posted platform, version info etc in your signature.
On the Mac at least a document double-clicked always opens in the last installed or updated program version. In your case, 8.1 has got that label from the O/S.
You could uninstall 8.1. Or re-install the latest version (insert CD and Repair would do, maybe). Perhaps just installing the latest hotfix will do it.
