Installation & update
Problems with printing to PDF AC10 1183
Hi!
Two problems got here.
1) I have a big layout - size A1. Sometimes, not always, but in approx. 50% of cases Amyuni PDF creator no matter how I arrange "page setup" feature turns printed *.pdf file view on 90 degrees - so if I have paper orientation "landscape" - it turns the result to "portrait" and cuts off the rest of the drawing. Is it ArchiCAD or Amyuni bug?
2) When printing to *.pdf file a layout which contains imported external *.pdf views - they just don't appear it final *.pdf file! Also this haven't been always - I could get normal result in 1010 version but no result in 1183 version. If there is some bond between versions, maybe this is just co-accidence.
1 REPLY 1
Djordje
Amyuni bug. Use A1 594x840 as the paper size. If you use only A1, it rotates.
This is a reported bug, I think ... and there is a cure too. Check the topic that advises all to stay on 1010.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
