ā2023-10-18 02:32 PM
Anyone else Archicad crashes when you go and change a text in elevation? I am using Archicad 26. I am going to upgrade to 27 to see if that helps.
ā2024-02-13 07:46 AM
Hi did it fix your problem?
i am on archicad 27 and using the test (free 14 days) enscape. It worked for a while although crashing all of a sudden sometimes, but now it just crashes archicad as soon as I launch it.
Anyone knows how to fix that? I really liked enscape and would like to buy it but not if it doesnāt workā¦
ā2024-02-13 08:11 AM
The original poster had a problem editing text in elevation.
This is a know MacOS problem when CAPS lock is on.
I believe the latest update (27.2) fixes this.
Is this your problem as well or is it an issue with Enscape add-on?
