  And I thought this was just
my problem!!!
I have spent
countless hours dealing with this demon
.  The aforementioned clicking on the parent folder in windows explorer would remedy. ArchiCAD was freezing constantly every time I copied, either using ctrl c or the contextual menu, or even the paste icon. Eventually it would deliver on the copy command but it would take forever, I was going
crazy! I went so far as to call Microsoft! Now, I have played with hi-po video drivers quite a bit and figured that was it, [ you play with fire, you get burned], but even uninstalling those and returning to "stock" drivers still resulted in freeze-ups.
Evetually with help and direction from microsoft's SP2 help line, [FREE], I solved the riddle. Here's
my
resolve, which by the way has worked for me, consistently! I
really hope it helps someone else;
I went into my startup registry, deactivated QuickTime,
and
 the Nvidia Nview [Nvidia Mctray], that ran from startup in my system tray, along with some other worhtless items, [ office, HP junk, etc. ]. I would reccomend evaluating all of the startup programs that run in the startup registry and eliminate, with
due caution of course, anything you deem unnesessary. There is a ton of "crap" that loads itself and runs, often without our "consent" and eats precious available memory. [ for example, check out your father's or daughter's startup registry sometime......] At least this is my understanding and I have had, as earlier stated, finally success with this method.
BTW: The Microsft beta Antispyware tool allows easy editing of your startup registry without going through the start>run>msconfig route along with the added bounus of enhacing your spyware protection and to the best of my knowledge it runs harmoniuosly with Norton and Mcaffe.
http://www.microsoft.com/athome/security/spyware/software/default.mspx
I would
most definitley defer to Karl on this and in fact hope he could add some further insight into how to proceed, and how all of this
really
 works,  if you are tempted to test my theory.
Good Luck!!
	jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
