!Restored: JAVA-pain in the neck!
i m trying to install archicad 10 bu come up with this pathetic message "an unhandled error occurred - specify system property 'is.debug' for more information. i had uninstalled all java environment software but still i get this frustrating message. where is this is.debug info anyway?
is it because of the configuration i have, a pIII 866mhz 512mb ram?
14 Replies 14
i did even try it on my laptop, a vaio centrino 1.6 1gb ram and get that frustrating message again!
please comment on it.
Djordje
What is the OS and is it up to date?
This is a Java based problem; if your Windows (I presume XP?) is not updated, this will definitely happen.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
xp pro
and up-to-date
i keep uninstalling the java, even the one that is setpup before archicad installation starts. everything seems to go well until it starts the install shield and misery shows up with that annoying message!
Gorazd
Do you have administrators rights on this account? I once read, that you must have them, or some vierd java mesages can come up during installation.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
yes i do have the admin rights
but no fix
Try this to create a log file during installation:
http://support.installshield.com/kb/view.asp?articleid=Q111177
how do i do that eric? i could not figure it out.
Sorry, it turns out that was the wrong url.
I looked a little deeper and found this:
http://support.installshield.com/kb/view.asp?articleid=Q110959
It basically says there is a conflict with Turkish regional settings. That rang a bell since your profile says you are in Turkey - so that must be the problem.
Then I found this:
http://www.netbeans.org/nonav/issues/show_bug.cgi?id=52012
Which is regarding netbeans and might seem irrelevant, but it instructs that the only known workaround for the installshield problem listed above is to change the regional settings in XP. Try changing it to english (or something else), then install AC 10, then change it back to Turkish.
I hope that works. If it does, GS should obvioulsy be notified about this.
thanks a lot eric! that really did set things going on course.
i should inform that i use a an english windows xp sp2 with regional settings set to turkish. i don't know if it is a problem with a turkish-interface-xp. but still the guys at graphisoft should take the issue into consideration, as eric pointed out.
cheers all!
