2009-01-22 12:16 AM
2009-01-22 12:44 AM
2009-01-22 12:53 AM
2009-01-22 03:16 AM
Mel wrote:The roof has always been in decimal degrees.
I'm using AC 12. I've already set all these setting to degrees, minutes and seconds, but the roof tool doesnt change with these setting. Thanks
2009-01-22 03:48 AM
2009-01-22 04:09 AM
Mel wrote:I'd love to know how you got this.
I know it can be done, because I've got an older file which i was working from which is set up like this. I attached an image. The one that changed is a copy of this file, but for some reason it has changed the setting. This has happen to me before. I reckon it might be bug in the program which is doing this, because I've never change the setting in the last couple of day while working on this file. It very strange. I wouldn't care if it was just a standard job but this file is to be our company template and i need to have the setting in degrees, minutes and second. I don't want to have to go back to original file and lost weeks worth of work.
2009-01-22 06:53 AM
2009-01-22 07:04 AM
2009-01-22 07:26 AM
2009-01-22 07:30 AM
