I was wondering if anyone could help me with a problem I'm having with the roof tool. I'm trying to change the roof tool so it draws in degrees, minutes and second. It's drawing in decimal degrees at the moment, it was originally set up to draw in degrees, minutes and second but for some reason it has changed, but I haven't changed any of the setting. I've check my units in Options/Project Preference and it set up correctly. Has anyone ever come across this problem. I need help to fix this as this is our template. Thanks
Ahhh it can be fixed though! Open a project that has the roof set to d,m,s, then copy any roof plane from that into your project with the dec. degrees (make sure you turn the working units back to d,m,s, first) and it will turn all the original planes back to d,m,s!
