Installation & update
Selecting Groups
This is probably a dumb question, but I'm new to ArchiCad and I can't seem to figure out how to select items that are in the same group; the tutorial says to use the arrow and shift-click, but when I do that it only clicks one components of the group. I am trying to click four walls that are in a group, but I can only click them one at a time. I wanted to find out this solution early because I know I will need it in the future.
Thanks!
Rocksand
Gerald Hoffman
This is one of those things that I believe are in the manual but you need to turn the "Enable/Suspend Groups" command to look like this.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Link
Yes, or toggle it using Alt+G.
Link.
I should have figured that one out! It's just hard to learn the whole program from scratch all at one time, after 10 hours of the tutorial I can get the major concepts but I get stuck on stupid minor things! My brain is numb!
Thank you!
