I have done this successfully several times and found it to be very easy to get up and running.
You just need to go to the WIBU website and grab the download for the Linux WIBU server.
Install that on your linux box, plug in your keyplug, and run the command '
WkSvLin'.
Thats it! If you have a firewall setup on it, you will need to open up port '
22347' as well.
In addition to the cool easy installation, the server management is great as well!
On any computers in the network, fire up a web browser and go to
'http://(IP address or name of server):22347'
Here you can check the usage of licenses, kick users, and a bunch of other stuff which i have never used.
Yay for Linux!
Josh Osborne - Graphisoft
