Scott Bulmer
Special Snap Option only allows Half
Using AC14 build 3477 I am only able to use the selection Half in the Special Snap Option located in the Standard Toolbar. Selecting any other choice will always revert back to Half. I have New & Reset All without luck. Please confirm this is a bug or if there is a workaround. Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
21 Replies 21
Cary Westerbeck
I wanted to follow up on this and say that Karl's recommendation to edit the toolbar and delete the "special snap" button worked great!
Thank you, Karl!
The first time I tried the fix I didn't do it correctly so I posted that it didn't work. However, I tried again and ensured that the special snaps was truly deleted on my toolbar and it's been working well for many days now. I use the Control Box for special snaps and it's working fllawlessly.
I know a few others on the forum have had this problem so if they find this thread I wanted to be sure they knew that Karl's fix is golden!
Thanks again,
-Cary
I have this same problem. I'm running Archicad 15 with all updates/hot-fixes and am running OS 10.7.4.
I pray this issue is resolved in Archicad 16 as it is seriously interrupting my work flow. These minor glitches can become so disturbing- I really rely on special snap values.
