Spool Folder Problems
I am having problems setting up my spool folder to plot. We have a HP 455CA oversize plotter. The plotter is set up on our server. I am trying to select the spool folder destination on the server but for some reason I am unable to select anything related to the server. I can only select folders on my desk top.
I am able to connect to my server fine out side of this particular operation.
ANYONE HAVE ANY SUGGESTIONS. THANKS
You will need to be more specific about the problem. Are you using Plotflow? How are you tying to connect? (Both when it works and when it doesn't.) What system is running on the server? How is the potter connected? Cab you plot directly from the server?
We are using plotflow.
We have a spool folder located on our server where the plotter reads the plt's and plots them.
I am able to plot if I create a folder on my desktop and i use that as my default spool folder. I then have to copy the plt's and past them on our spool folder located on our server.
We are running MAC OSX 10.2.8 on our server.
The plotter is connected to the server.
We do plot from our server.
