Stairs not showing on the Layout. Going mental.
I have this drawing and a saved view of it but when I place it on the layout the stair misterously disapears. The renovation, pen set and layers are all the same. Did someone already had this problem. Here it goes some images of the screen. Please heeeelp.
1 Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hello,
Thank you very much for the report and I am very sorry to hear that!
Instead of changing the Renovation status, have you tried changing the Show on Renovation Filter option instead?
Simply change this option to another Renovation Filter, then change it back to All Renovation Filter will also solve the issue in some cases.
Please let me know if it works!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Go to post
29 Replies 29
Miha_M
Saved View maybe? Do you have any other element on the same Layer & Renovation status which does show on Layout?
I see the View highlighted on your first screenshot, but it must not be the one placed on Layout. Try checking the link to the desired saved View on the Layout drawing. Select the drawing on the Layout, > right-click > select "Link drawing to..." > select the saved View, where the Stair does show.
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Narska
Has this been resolved? same issue
Tomasz Mlynarski
New York based Architect
jl_lt
Ace
This may sound very basic, but I would check the following:
-make sure the stair object it's in the proper layer according to the layer combination you need (also, that the layer un which the stair should be is turned on)
-make sure that your saved view has the correct layer combination attached to it.
-if your are working with many clonned folders make sure that You are actually dragging the correct view into the layout (This happens to me once in a while. That is why i suggest to implement the ability to color code saved views!)
-on the layout, enter on the dragged plan properties and check that both pen set and layer combination are set to the default You established in your saved view.
DGSketcher
Legend
If you look at the layout contents, the plan view used is not the same view name as presented in the view image.
Foti
Hello everyone
Has anyone been able to solve the issue? I started a new project from a template and just noticed this happening. Everything that was suggested has been triple checked.
Foti
Thanks
AC22
Foti B.
AC25
PC Precison 5760, Xeon 11955, 64GB, Nvidia RTX A3000
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Foti,
Thank you for sharing the issue and I am very sorry about the experience!
We had some record in our database about such issues, but unfortunately, we did not know why it happened, since there was no proper method to reproduce the bug!
There were some cases where the issue was fixed by setting the stair to another Renovation Status, then set it back to the old one, after that the stair would appear on layouts.
Let me know how it goes!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Hi everyone,
I've experienced the same issue in Archicad 23 (INT 4006 Win64 FULL).
I can confirm that the issue can be solved as simple as Minh suggested! Just change the Renovation Status of the stair, make an update of the Layout and then change the status of the stair back to the desired Renovation Satus and it will show up on the Layout!
It worked for me, thank you Minh for your intervention!
Best regards,
Felix
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Felix,
Glad I could help!
Have a nice day!
Minh
Minh Nguyen
GRAPHISOFT
Foti
Hi mnguyen
Yes i did that change reno status and back, it worked.
Thanks
Foti B.
AC25
