Installation & update
Starting up archicad 22
Every time I try to start up archicad I keep getting this bug report error
This is not really enough information for anyone here to help you with.
Send the bug report off and take note of the number.
Then contact your local support and mention that bug number to see if they can help you.
In the mean time does this happen when you try to start the program or when you actually try to open a file?
If it is just when starting the program then I would try re-installing.
If it is when you try to open a file then try a different one or the default template.
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Also, you should try the first Preview update of ARCHICAD 22. Maybe this problem is already fixed in it.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
