Installation & update
TRACE REFERENCE - images not appearing ?
Having an issue with a images on a worksheets, not showing up with trace reference in plan ?
however everything is, (lines fills etc) on that same worksheet ??
any ideas ?
Check the visibility settings for your reference.
You may have 'Drawings' turned off.
thanks barry, forgot about those options
