The session report window is missing?
Stig Bengtsson
I select it under file/info but nothing shows up? AC17
Stig
Architect AIA RIBA SAR/MSA, Graphisoft Registered Consultant
AC19 SWE 7006
AC20 SWE 4012
1 REPLY 1
Try these two things in this order:
1. After you activated File\Info\Session Report, check the Window menu. Do you see "Report" listed there? Maybe it is minimized. Select Window\Report and its minimized window may appear towards the bottom left of your screen. Then you can enlarge it.
2. Go to the Work Environment Dialog\Palette Schemes and apply the Standard Palettes scheme.
Does it show up then?
If it does then it probably somehow to to an area of the screen not visible at your current resolution and that is why you couldn't see it.
