Installation & update
Trouble with "Custom Scale" printing
Just installed 19 and started my first 19 project. When I attempt to print and choose a "Custom Scale", I get a spinning/waiting cursor icon and it hangs. Is anyone else seeing this problem? Any ideas how to correct it? Thanks
1 REPLY 1
Katalin Borszeki
HI, If you choose feet or inches as model units in Options > Project Preferences > Working Units > Model Unit, the custom scales bar will be empty. In the US, these units are defaults, so you don't need to change them, just in case you would like to try with decimals.
This bug has been added to our Defect Database. It is planned to be fixed shortly. A possible workaround is to add the scales manually. Thanks,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
