Installation & update
Uncontrollable EXPLORE MODE
iggiv
Team,
I’m writing to report an issue with the EXPLORE MODE movement while I use Archicad 28 and “TypeIt4Me” software. It appears that using this software causes an uncontrollable downward movement of the 3D model, and the only solution is pressing the SCAPE key.
I’ve already reported this incompatibility to them after their release of version 7.1. I believe it’s worth reporting this issue to Graphicsoft to see if you can take any action on your side.
I find TypeIt4Me very useful, but my primary software use is Archicad. I don’t use it with Archicad itself, but I use it with all other programs.
I hope this issue can be resolved soon so that I can use both software together.
Thanks,
iggiv
Team,
I have an exciting update to share! I installed the AC28.3.0 update, which isn’t officially the final release but is available on the update webpage with a note. I decided to download it for testing purposes.
Great news! So far, my issues with TyIt4ME and Archicad seem to be resolved. It’s working great, and I hope I don’t need to report any further problems.
I’ll leave this ticket open until the end of the week to ensure that everything works as expected. There are no issues in the EXPLORE MODE.
Thank you to Graphisoft for this great update!
iggiv
Another update:
The previous post was too good to be true. Here’s what I did:
  1. After not using TypeIt4Me for a while, I decided to give it another try. I opened TypeIt4Me, then opened AC28, and everything seemed to work fine.
  2. However, when I quit AC28 and opened both AC28 and AC29, the problem reappeared. I quit everything and opened AC28 without TypeIt4Me, but the problem persisted.
I’m not sure what to say, but I’m closing TypeIt4Me and not using it until a new version of anything is available to test.
