Installation & update
Update AC 20 Mac
Brett Brown
Can anybody please tell me why I am getting this error from a update downloaded from the Graphisoft Website. Even allowing it in System Preferences doesn't work
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
5 REPLIES 5
I don’t think AC20 is compatible with Big Sur. Apple introduced strict app signing.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
https://community.Graphisoft.com/t5/Setup-License-articles/macOS-11-Big-Sur/ta-p/304187
there may be a workaround.
Lee Hankins
This is for AC21 on Catalina but may help fix your issue but it sounds like you may have already tried this.
https://www.macworld.com/article/672947/how-to-open-a-mac-app-from-an-unidentified-developer.html
Lee Hankins
Installed AC 20 from Disc without any problems and works well but I can't update it to 8005. Tried most of those suggestions but none worked. Seems to use the Java in the installer of 8005 instead of the installed one on the computer.
I can only assume that it is not supported in Big Sur. There may be a workaround if you can contact local support.
Lee Hankins
