Installation & update
Update AC11
Hi All,
My Name Eddy Rachmat
From Manokwari - Indonesia
I'm new user AC11 INT Full Version
My AC11 Build 966 problem can't update to AC11-1033b and AC11-1040 Build Version
This Archicad 11 Hotfix has not found an installed Archicad to update
- Finish updating and leave the installer
- Browse for Archicad and update it
-Back -Next -Cancel
I'm browse to directory C:\Program Files\Graphisoft\Archicad 11 and
(No appropriate Archicad is found in this folder
Close this box, then browse for another location or click Cancel to quit the installer)
Why can't automatic update from 966 Build to 1033b Built and 1040 Build?
Sorry My English
AC10-1188 INT Full, AC11-966 INT Full, 2xOpteron2210,4GB ECC Reg,Geforce8800GTX,LCD VG2230wm.
5 REPLIES 5
Djordje
How did you get 966? The first available version was 970/975 and it updates no problem.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hello Mr. Djordje
I'm Sorry
I'm used release 966 and information GRAPHICD :
CD TITLE: AC11-INT
CD ID: AC11-INT-C2006
PACKAGE NAME: ArchiCAD 11 R1 INT
PACKAGE VERSION: 1.1
DATE: 2007.5.11
PLATFORM: WINDOWS XP, XP x64
LANGUAGE: ENGLISH
FILE VERSIONS
ArchiCAD 11.0 R1 (0966)
Add-Ons 11.0 R1 (0966)
Plotters 4.08
PlotFlow 1.4
InstallShield MP 5.03
Setup 2.51
WIBU 5.00
QuickTime 7.1
LOC KG, TV
Information CD no compatible upgrade to AC1033b and AC11-1040, I'm uninstall clear AC11 and I'm used AC10.
I'm upgrade dongle AC10 to AC11 and waiting CD AC11 from Reseller
its now running AC10 1088, my dongle is best detect WIBU server monitor.
I'm download AC11-INT from www.download.com for solution versi 970/975.
Thanks Mr. Djordje and sorry my english.
AC10-1188 INT Full, 2xOpteron2210,4GB ECC Reg,Geforce8800GTX,LCD VG2230wm.
Djordje
Check the Release Notes on 1033 - it clearly says that it is an update working on 970, not 966. The installation CDs are 970, so your reseller should give you one.
Djordje
HP Omen
Hello Mr. Djordje
I say thank you
I have get archicad program update for 970 to 1033 and 1040 build and so I can installed My program succesly.
I'm used version AC11-1040 now, thank you very much
Eddy Rachmat - Papua Barat Indonesia
AC9-2219 INT Full, AC10-1188 INT Full, AC11-1040 INT Full, 2xOpteron2210,4GB ECC Reg,Geforce8800GTX,LCD VG2230wm.
Djordje
G-reat!
Djordje
HP Omen
