2023-10-15 02:50 AM
I am currently running AC 23 with Mojave on a 2018 MacBook Pro 2.9 GHz Intel Core 9 with 32 GB of memory and a Radon Pro 560X, 4GB. I am planning on backing up and erasing my drive, installing Ventura and AC 27.
I am not sure about Sonoma at this time (or AC 27, as I considered installing AC 26... any input would be nice).
Does that make sense? I figured that I can upgrade to Sonoma later if it makes sense at that time.
I noticed that Sonoma will be the last OS I can run on my MacBook Pro.
Basically, would I be better off running AC 26 and Ventura? Pros and Cons...
Thank you all,
Greg
2024-01-15 12:30 AM
HI Greg,
Did you ever get a good solution to this? I have mojave and running AC24 fine but need to install AC27 and wondering if it will work.
