Installation & update
Installing or updating your app. Hardware/software requirements, OS specs.
WIBU-Key
I have recently purchased a full version of ArchiCAD, i also have an educational version on my pc. both use the keys and im having problems getting into my professional version because it says it cant find the wibu key. can i download the driver from a specific site? any help would be great.
4 REPLIES 4
Go to WIBU.com and look for the end user updates. (I think thats where I found the latest). Reinstall and the key should be recognized.
Lew Bishop
P4/2.8 XPHome/AC9
Go to WIBU.com and look for the end user updates. download the latest -Reinstall and the key should be found.
Lew Bishop
P4/2.8 XPHome/AC9
You can also just go to the WIBU folder in the AC 9 installation CD. I had one computer of four that I've installed 9 onto that did not recognize the WIBU driver after a normal installation (install 9 without key, reboot, plug key in for autodetect) ... and I had to manually install WIBU, reboot, and then all was fine.
The educational (student) version does not require a key, AFAIK... unless somehow you have a university (lab) version installed (which is protected).
Karl
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thank you for all of the help, i have successfully gotten my key to work using the website provided
