Gorazd
Waking Mac from sleep disconnect cm keyplug
My coleagues iMac has CM single keyplug attached and everytime his mac goes to sleep and wakes again, archicad reports "no keyplug" and offers him to save or quit. Does anybody know the solution? It is brand new iMac with Lion.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
3 Replies 3
You might try having him download and install the CM driver from here:
http://www.graphisoft.com/support/archicad/downloads/WIBU.html
(system restart required).
After upgrading to Lion, I had a problem that the CM daemon had to be manually started for AC to recognize the CM key. Reinstalling the driver from the link above resolved that ... no problem waking from sleep either.
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Gorazd
Thank you for suggestion. Will try it.
Gorazd Rajh
Maybe these wiki's can help you:
www.archicadwiki.com/WibuKey/Troubleshooting#ArchiCAD_forgot_the_local_Key.2C_if_I_Wake_up_Mac_Intel_from_sleep
www.archicadwiki.com/WibuKey/Troubleshooting#Keyplug_is_not_found_after_waking_the_computer
