Dennis Lee
Wibukey server counts AC14 and AC15 on same machine as two!
I'm trying the wibukey server for convenience, and found out that when a user opens up AC14 and AC15 at the same time that person uses up two licenses. Is this a limitation of the wibukey server or is there a way to fix this?
When it's plugged into the local machine, I was able to open up multiple instances of AC14 and AC15 at the same time.
Can someone help me?
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
9 Replies 9
I have had the same issue. Not sure there is a work around for this.
Dennis Lee
This should be considered a bug, then, right? Why shouldn't it work the same way?
This is a pretty big limitation for the wibukey server.
Windows 10 x64
Since ArchiCAD 9
See if this article and the discussion of 'version groups' might address this issue:
http://www.archicadwiki.com/ProtectionKey?highlight=%28version%20group%29
That article needs updating - no mention of 15 - but what you are experiencing makes it sound like GS made 15 its own 'version group', rather than grouping it with 13, and 14 (which would have made more sense since they are the versions having TW2).
So, maybe a bug, or maybe intentional? You might contact tech support for them to sort it out.
Dennis Lee
Thank you Karl! That seems to be it - I will follow up w/ Tech Support and post results later.
Thanks again.
Windows 10 x64
Since ArchiCAD 9
You're welcome, Dennis. Look forward to hearing what verdict support provides.
This is a real problem for a company like I work for.
We are a project home builder so have standard model plans in various versions of Archicad dating back to version 6.5
Quite often we will find ourselves copying & pasting from one file to another.
Everytime there is a new "version group" then we are effectively doubling the need for our licenses.
Of course it is not that bad as not everyone is using different versions at the same time.
But everytime there is a new "version group" we have this problem of running out of licenses.
We try to make a point of updating our popular standards to the latest version but it is not possible (feasable) to update them all (they number in the thousands once you include all the differnet construction materials we use).
If multiple versions can be made to work on a single license key then surely the same can be doe for a network license?
Marton Kiss
Unfortunately this is a technical limitation with Wibu software protection and AC15 does belong to a new version group.
Switching to CodeMeter protection solves this problem - all CodeMeter ready versions (10-15) can be run side by side with one network license. Your local reseller can help how to exchange your Wibu key to CodeMeter:
http://www.graphisoft.com/purchase/
Regards,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Regards,
Marton
I'll have to check again but I think the cost is a little prohibitive to do that with 105 licenses.
Thanks for the suggestion.
We are a project home builder so have standard model plans in various versions of Archicad dating back to version 6.5.
I believe the fee is pretty small to switch from WIBU to CodeMeter keys (which is a WIBU product, so not to be confused with WIBU key), as suggested by Marton.
But, do note that the CodeMeter key cannot run 9 or earlier. Those earlier versions will only open in demo mode, as if no key is present. (Well, there is one special exception.)
So, if you do have projects back to 6.5, you may want to keep one solo WIBU key around if you think you might need to edit or print any of them in the older version for some reason. (If all you need is to open them - demo mode is fine, or to convert them, 10 can open back to 6.5 - so CodeMeter is fine in that case.)
