Xerox 510DP or KIP 6000 compatibility
New to ArchiCAD and need to make a decision on a wide format Plotter, between the Xerox 510DP and the KIP 6000. I notice there is not a driver for the KIP plotters with the ArchiCAD 10 installation and was wondering if someone could inform me on the compatibility of Archicad with either or both of the two above plotters.
Thank you,
Link
Try doing a few searches here. You may also find this helpful:
http://www.graphisoft.com/support/archicad/archiguide/readmeplotters.html
Link.
I haven't any direct experience with either, but I have heard better reports on the KIP than the Xerox. I think Tom Waltz has used the KIP quite a bit. Oce is also very good for high volume and Epson for high quality color.
Too early...
