archicad launch failure
I moved my computer to a new location. When I tried to launch archicad from my tool bar it had disappeared. I went to the harddrive to launch it from there. I got a prompt on my g5 powermac
! application launch failure
The application "ArchiCAD" could not be launched because of a shared library error:
"<archicad><archicad><GSCppRuntimeLib><>"
I've been working in ArchiCAD since 1994 and have never experienced this problem.
Yikes!
For members of the forum to better help you, place your AC version, operating system, and hardware info in your signature block.
That's exactly what I said ! In 14 years of use I've never seen that prompt. Thanks for the info heads up.
Mark
Thomas Holm
Because you moved your machine, Archicad can't find it's way back to where you left your shared library.
If you want better help, i think' you'll have to follow Laura's advice.
