2026-02-20
03:41 PM
- last edited on
2026-02-24
11:39 PM
by
[Moderator: this topic was moved into its own thread from another thread]
i have the same issue with the home screen no longer responding.
I can have 4 projects open with no issue.
As soon as I go to launch a 5th instance of archicad, it hangs at the home screen and requires the process killed.
Been that way for AC26 / AC27 and now AC29.
AC24, I never experienced that limitation.
2026-02-21 01:55 PM
Wow, now that you mention it, the fifth instance might be the reason! I have a 4×project with hotlinks / modules and usually I have two or three instances open, but now that you've written this, it really seems to me that it might be exactly the fifth instance that's causing issues.
2026-02-22 06:00 PM
I would like the moderators (@GRAPHISOFT ) of this forum to move discussion above to be moved to separate threat since it is about a known DEF-24804.
At this moment, it is reccomended to start a new instance of Archicad via already running one with:
2026-02-24 11:39 PM
I moved these posts into a new topic.
2026-02-25 02:15 AM
Another reason to kill the Home Screen...
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2026-02-25 08:32 AM
As a workaround you can open your projects directly from explorer / finder. This skips the home screen.
AC25 doesn't have this issue either.
I reported this about a year ago to my reseller and as I recall GS was aware of the problem and it was supposed to be fixed. Anytime now?
2 weeks ago - last edited 2 weeks ago
I wonder if they will ever fix this issue with the Home Screen. Wonder if it still occurs with AC30?
ps. Seems like it is still the same in AC30.
