JeffH
Not possible to run more than 5 Archicad instances
[Moderator: this topic was moved into its own thread from another thread]
i have the same issue with the home screen no longer responding.
I can have 4 projects open with no issue.
As soon as I go to launch a 5th instance of archicad, it hangs at the home screen and requires the process killed.
Been that way for AC26 / AC27 and now AC29.
AC24, I never experienced that limitation.
AC24 / AC26 / AC27
Win10
5 Replies 5
GG_rakurs
Wow, now that you mention it, the fifth instance might be the reason! I have a 4×project with hotlinks / modules and usually I have two or three instances open, but now that you've written this, it really seems to me that it might be exactly the fifth instance that's causing issues.
ArchiCAD 28 | INT - Cro | Forward | WIN 10 / 11
Karel Landa
I would like the moderators (@GRAPHISOFT ) of this forum to move discussion above to be moved to separate threat since it is about a known DEF-24804.
At this moment, it is reccomended to start a new instance of Archicad via already running one with:
  1. Command "New" or "Open"
  2. Home screen (since AC28ú and launching one of the recent projects
From Archicad 17
MacBook Pro M1 Max
I moved these posts into a new topic.
Lingwisyer
Guru
Another reason to kill the Home Screen...
Erwin Edel
As a workaround you can open your projects directly from explorer / finder. This skips the home screen.
AC25 doesn't have this issue either.
I reported this about a year ago to my reseller and as I recall GS was aware of the problem and it was supposed to be fixed. Anytime now?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
